We have a hot tub retailer in a new tenant space in a building with a 3-phase 208V Wye service. Their show room hot tubs require 240V split-phase (center tap neutral - standard 1-phase power). We have proposed 3 - 208 to 240 isolation transformers with the center taps of each connected to the service neutral. Question is - can the H1s be connected to the adjacent transformers' H3s to form a Delta configuration and feed a single 3-phase panel (the preferred approach) OR must the high outputs of the transformers remain isolated and feed 3 independent 1-phase panels (the default approach)? My phasor diagram indicates it should be OK, however this is in no way a common configuration making me think there be an issue. I appreciate your feedback and welcome an explaination as to why the delta configuration will not work.
