LarryFine
- Henrico County, VA
- Electrical Contractor
Yep. I once used that method to troubleshoot an intermittent breaker tripping in an older house. It ended up being a cat-urine-soaked receptacle in a Wiremold box behind the front door.Are you assuming that there is something loose associated with the circuit that will be revealed by the light bulb while wiggling devices and switching loads?
The bulb acts as a current limiter, so the breaker won't trip. The bulb brightness, and steadiness of brightness, provide valuable clues. In my case, the bulb flickered as the receptacle arced.
