renosteinke
- NE Arkansas
Yes, it is. Here is how it happens ....
It starts with an old fuse box, one that has 4-Edison base fuses and two sets of NON fuses. One set of the NON fuses is the main disconnect, and uses 60-amp fuses (largest value made). The other side was usually wired for a range, and had 40-amp fuses with #10 wire. (I seem to recall an understanding that allowed this for range loads, since they were so intermittent).
The trouble is, this is the only 240-volt circuit in the panel. So, years go by, and the first thing that happens is that they need 240 for that new-fangled 'must have' appliance, the clothes dryer. Now they've got a 30-amp appliance 'protected' by those 40-amp fuses. Still, since folks seldom cook and do laundry at the same time, it "works."
Then they decide to replace the gas water heater with an electric one - perhaps because the gas line has rusted through. Where to get 240? From that same circuit. They start blowing fuses, and after about the third trip to the hardware store (or first call to the rental agent), the 40-amp fuses get replaced by 60-amp ones. They'd use bigger ones if they could find them.
All these 'additions' invariable get spliced into the wires, usually at the point closest to the attic entrance. Naturally, there's never enough 'extra' wire to bother with using a box. The splices are usually made by skinning some insulation off the wires and wrapping some stranded wires (from a cheap extension cord) around the old K&T, then wrapping it all with tape. Then some new insulation is piled atop all of it.
The problem isn't K&T. The problem isn't "Edison base" fuses (or any sort of fuses). IMO, compared to the flying, loose splices, fused circuits, and under-protected appliances, the use of the cord material is a fairly minor risk.
