- Tennessee NEC:2017
- Semi-Retired Electrician
I had a prospective customer ask if I could check out the wiring in an old house they are trying to buy, maybe built in the 20's or thirties. Other than visually checking the wires that I can see or get to easily, what is the best way to check them. I know to check continuity and for open or shorts. I guess I need to know the condition of the insulation of the wires. I don't have a megger, which I know that's what you should use if you can. I'm just starting out and don't want to buy every tool available until I get established (more coming in than going out). Are there some tricks that any of you use without using a megger? Also, I did look at some meggers and saw all types of voltage ranges, brands, and especially prices. What is a good reliable one that is not in the mega-bucks price range? Also, what voltage range meter would I need to look at?
