Gas Water Heater
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Does anyone know if it is possible to control a gas water heater with a timer somehow? This water heater has an automatic ignition- no pilot and I see wires in there.
Is it possible to interrupt the ignition wire or would that void UL? I have a client with a gas water heater and she wants to be able to turn it off automatically during the evenings and when they are away.
John120/240
Olathe, Kansas
If no one is home, there should be no need for hot water. So if you cut the gas
supply off with a timer, how do you maintain the tempature in the tank? If you
come home & wish to shower how long would you wait for hot water?
Dennis Alwon
Chapel Hill, NC
I may have the answer. You take of the knob and slip this on.
Click Here
Dennis Alwon
Chapel Hill, NC
I think that is managable with a timer. If you come homwe at 5pm everyday then you set the timer for 4:30 pm. The tank won't be stone cold so less than 1/2 hour to heat it.
Dennis Alwon
Chapel Hill, NC
Wow, not much response here. I am thinking a solenoid valve on the gas line may be the way to go. Anyway see an issue with that.
G._S._Ohm
DC area
The one water heater I measured lost 50 w through the insulation so this gives a measure of how much the water temp. will drop.
Post a schematic of the heater; controlling a gas water heater is one thing but controlling it reasonably safely is another.
And there are more problems switching a 28 mV thermostat than a 750 mV one.
roger3829
Torrington, CT
Shutting off the gas won't keep the unit from trying to ignite. That may cause a problem. After so many attempts it might lock itself out. Have not tried to do this before.
Dennis Alwon
Chapel Hill, NC
This is why I think a solenoid valve on the gas line would be the best option.
G._S._Ohm
DC area
My WH experiment showed that with no water usage it was 5 hours before the 'stat asked for heat, so a timer set for 5 hours would make no difference at all.
Solving for the likely energy savings for longer timer intervals is a very messy calculation.
If the client does save some $ they are trading this off with a slight risk of danger due to the water heater being fooled into doing something dangerous because the heater is expecting a more or less steady supply of gas.
The danger will vary depending on where you put the modification.
Dennis Alwon
Chapel Hill, NC
That is a good thought. I really don't want to do this but I told her I would check into it. Sounds like there would be some savings but not significant amounts.
hurk27
Ok if this WH is pilot-less ignition it has to have a 120 volt supply for the igniter? just put a timer on this supply?
Any other interruption of allowing the water heater to light will result in a sensed error to the control which will shut it down, if the WH has a wired thermostat, it can be interrupted with a dry contact.
