I'm putting together a proposal for a new 800a service. It's a freestanding service -no attachment ot a building. I've got a 42"Wx62"H  safety switch, a 42"Wx76"H MDP, and a 22" wide sub panel. In the past I've just used pressure treated lumber but I've noticed some old services around here like that that have the post rotting out. So, I want to build this using galvanized and stainless steel. For the piers I'm going to use 4"x4" galvanized square steel tube 1/4" thick but that's about as far as I've gotten as far as framing. Maybe Unistrut accross the piers to mount the equipment? Will that be hefty enough to hold the stuff?
if it were mine to do, and i didn't want to use a piece of switchgear,
i'd use back to back strut, galvanized. either 16" hole 3' deep, or
sonotube, and put the double strut in it as uprights, 4' on center.
then 1 5/8" strut across as needed, using allen head cap screws,
flat washers, and spring nuts to hold it, instead of square washers
and hex nuts, so the surface of the strut is available for mounting
without obstruction.
if space permits, you can mount stuff on both sides of this, and
nipple between them, for a clean install.
a single piece of 2 1/2" strut across the bottom of this sets
your conduits at the right amount of standoff
unless you are in a food prep area, galvanized is better than
stainless steel. especially in saltwater environments. i've seen
stainless eaten near the beach, while hot gal right next to it
was unaffected.
stainless steel US made often has a great deal more nickel in
it that "unsourced" stainless, which can come from anywhere,
and often has just enough nickel in it to not rust till the check
clears the bank.
if it says "304 type stainless", that is what you are generally looking
for.
you can't afford "316 type stainless". nobody can. :roll:
i tried pinging for a price on 304 strut, and could only find "call us"
