mstephenson
I have a situation where a competing electrical contractor for a fairly good sized job has informed a potential customer that he can re-use an existing 12 year old 3000 amp switch gear with a 208/120 volt name plate and UL listing at 480 volts. The switches in the gear are rated at 600 volt. I have talked with one of the gear manufactures engineers and he said that the buss was probably rated at 600 volt, but they would not put that on paper or guarantee it at 480 volts. My questions is, Am I wrong in saying that using this gear would be a violation of the NEC code as it is not UL listed for use at 480 volts?
