I have a production area that?s Class II, Division II, Group F (Dusts, Contained or not present in normal operation, Carbon Dust).
The Operator?s Interface is via a PC/TS (Xycom 15? PC / Touchscreen) mounted into a NEMA 9 enclosure (Rated for Class II, Div I, Group E, F or G).
Also, in this enclosure are a power supply, duplex outlet, CBs, etc; which are not Class II, Div II, Group F; but since these are inside the enclosure these don?t have to be certified Class II, Div II, Group F.
The PC/TS manufacture has discontinued my current PC/TS and their replacement is only certified for Class I, Div II, Groups A, B, C, D.
The question is, can the new PC/TS be installed into NEMA 9 and still meet code requirements for the room? The only exposure to the room is the bezel / Touchscreen, all the electronics (chassis) is essentially inside the NEMA 9 enclosure. The bezel?s gasket / seal is certified Class I, Div II, Groups A, B, C, D which is rated for Gases and Vapors. So you might think this would also keep out Dust
