ElectricianJeff
 - Southern Illinois
I have a job this Friday that has me second guessing myself.  This is in an area that I don't do alot of work in and I am not familiar with the inspector.  This is a result of a city inspection do to a change in occupancy and I am getting my information second hand from the homeowner.
This is a 100 amp. push-matic split bus panel. The two 50 amp. mains are located in the middle of the bus. The inspector has a problem with the fact that 2 different breakers have to be pushed to disconnect power. In reviewing 230.71 and 230.72 ('05) this existing installation meets my interpretation of these sections.
I will be installing a 100 amp exterior disconnect since the meter base is about 15' from this panel.
According to the HO the inspector wants a plate attached to these 2 breakers to allow the service to be disconnected with just one push. My thinking is that the field modification of this existing panel is more of a code issue than what presently exists.
I would be interested in any input on this in case I am missing something.
