Scenario: A building is served by two outdoor pad mount transformers, one that is 480 volt secondary and one that is 208 volt secondary, and each transformer serves a respective indoor switchboard.
My question is: if each switchboard is to have an outdoor triad ground, is there a minimum distance these ground rings should be spaced apart? Or should they be bonded together? Not the rods in relation to each other but the spacing between each system ground ring.
