 - Chapel Hill, NC
 - Retired Electrical Contractor
That would work but remember if you are under the 2008 NEC you would need 4 wires and you also need to use ground rods or other electrodes.what is that rule this is a single fam dwelling with a 200 amp service i put a 100 amp brk in the main panel and put a main lug with a 90 amp brk and a retention clip in the garage that is detached so would you say that would safice for the rule
