- Bremerton, Washington
- Master Electrician
I need to design a low voltage cutoff circuit for a 12 VDC gel cell battery, that normally is on a charger at 13.7 volts
The circuit will open a relay before the battery voltage drops too low making the recharge cycle too long.
(common battery as used in fire and intrusion panels)
Whats a reasonable voltage for a cutoff circuit?
