chrisrappl
 - Raleigh
I have a residential job where the owner has asked me to run a 240v-20a circuit from the main panel to the 3rd floor for a PTAC unit.  The panel is outside and he wants to run EMT on the exterior of the house up to the attic and then continue the cable, through the studs unspliced to the receptacle box.
Can I run 12-2 UF in 1/2" EMT? I believe that 340.10 (3) allows me to, however I don't think that I can satisfy 340.24 (bending radius of 5X) if I use an LB to enter the building.
I would use rain tight compression fittings, mineralacs to keep the conduit off of the wall and UF cable since the inside of the conduit is a damp location. The UF cable would continue unspliced through drilled studs to a NEMA 6-20R which would provide the disconnection means for the PTAC unit.
