I have been provided with a spec for a towel warmer manufacturer by a company called Waterworks. This particular model is hardwired and provided with an 8' cord "whip." The instructions say, "Wire set should be pulled through a conduit to a single-pole junction box equipped with either a dimmer switch (which controls heat level) or a standard single-pole illuminated toggle switch."
The cord existing the unit is type STOW, which is covered under section 400. I'm having difficulty finding any section of the code that would allow this cord to be pulled through conduit and then terminated in a junction box. Section 400.8(6) prohibits cord from being installed in a raceway except as otherwise permitted. Frankly, even supplying this cord without a plug would seem to violate 400.7(B).
There is no section of the code specifically that covers towel warmers, but I think they fall under 422 (appliances). After reading through this section and again through 400, I still can't find anything to allow this. I think the towel warmer should be provided with article 300 complaint wiring, such as a flex & THHN whip, MC cable, etc.
Does anyone else have enough experience with this type of device to let me know if I am missing anything? Most of the other wardwired towel warmers I could find information on are meant to be mounted directly to a junction box (unlike this product).
Thank you.
Thank you.
