powerplay
- In front of a computer.
a) I have heard that the 240 volt in floor heat mats put out more heat than the 120 volt ones, but I am thinking it all depends on the watts. Do the 240 volt heat mats heat up faster?
b) I'd be curious to know if the custom heat mats are constructed better and last longer than the manually strung ones or vice versa? The manually wired ones would have better coverage, but I'm thinking the quick install heat mats would be able to radiate into adjoining tiles enough to prevent frostbite on the toes reasonably well? I'm leaning towards 120 volt self wired although it would be fairly easy to run 240 volts to the panel, but I'd appreciate any feedback or preferences to the contrary.
...thanks again!
...thanks again!
