We are doing a project that requires 1700 Compact Flourescent Bulbs
We are using 2-200 Amp 3 Phase 120/208 Lighting Contactor Panels.
The A,B, & C Phases are Balanced @ 50 Amps per leg but the Neutral is @ 129 Amps. I have never seen this.
Question is, is this normal on Compact Flourescent Bulbs and if it is, is it going to cause any problems in there transformers or any of there other equipment, and if this is true what should we do to correct it.
