Ragin Cajun
- Upstate S.C.
My code books go back only to 1993. When did the NEC start requiring phase identification by separate color coding?
Thanks,
RC
Thanks,
RC
Notice 210.5(C)(2)"separate color coding, marking tape, taging, or other approved means."My code books go back only to 1993. When did the NEC start requiring phase identification by separate color coding?
If it's other approved means or tagging I guess it don't have to be colored - intersting?
IMO, there should be a standard color code for 120/208v and 277/480v systems ( black, red, blue, brown, orange, yellow) . I guess the NEC thinks it is more important for them to design circuitry and pull neutrals to switches that may never be used.You can always mark them using circuit numbers.
IMO, there should be a standard color code for 120/208v and 277/480v systems ( black, red, blue, brown, orange, yellow) . I guess the NEC thinks it is more important for them to design circuitry and pull neutrals to switches that may never be used.![]()
I bet orange wouldn't be in that list if they ever did.IMO, there should be a standard color code for 120/208v and 277/480v systems ( black, red, blue, brown, orange, yellow) .
Why would it be a bad idea to standardize color codeing? I don't see the problem with that. Please explain.
For me at least two reasons
1) There is no reason that numbering, labeling or other method is not as effective.
2) No one should be making decisions about voltage based on the marking of a conductor.
What voltage is this below?
How long has green been designated as a EGC?
1- Your picture shows someone who obviously doesn't care about the code, regardless of what is written
Probably.
2- High leg orange.....please explain why its in the code than
No idea, makes no real sense.
3- It standardizes the color coding for different voltage systems and make things a little safer IMO
And how would you deal with all the existing installs?
It's always seemed that this could be taken to mean other effective means of making it orange.It is not required to be orange it can be marked by other effective means just like any ungrounded conductor.
I think we could prevent a lot of unqualified people from working on electrical systems if all conductors were required to be black. Then you would have to have some idea of what you are doing to work on the systemAnd it is would increase the man hours required to do a job and I get paid by the hour.
There would be no white or green either in my planOther than places where required to be green, white or gray they can all be black. Any other idenitification method is up to the installer.
