Alwayslearningelec
- NJ
- Estimator
Anytime you core drill through a slab I imagine you can hit rebar. Is x-raying of a slab always required and if not how to you avoid the rebar? THanks.
Static poured floors for conversation is not a problem the holes are to small, Dynamic Floors that are loaded with pulled tension strains is a whole different story. X-ray any tension floor.
It makes a big noise that can be heard throughout the building, too. Trust me. :roll:Cutting into a pretensioned cable is not a good thing and can be a very costly mistake!
None prestressed slabs with re-bar are no match for a coring machine -- just goes a little slower as you go thru the rebar. Of course it can go thru a raceway too???
In my first year as an apprentice I was asked to help find an open circuit in a factory. I had worked in industrial maintenance before I came into the apprenticeship and loved chasing down wires. I located it, someone had core bored a 4 inch hole through a 2 inch rigid pipe in the poured concrete floor. They cut right through all three phases of a 60 amp 440 volt branch circuit. I always wondered how that could have happened without the person doing the boring noticing. First, the circuit was live when it was cut. Second, have you ever done a bore through a wall or floor and not looked into the hole when you were done????
