Designer69
gents, I would like to understand something and hear from both engineers and electricians.
Say I have specified a 3/4" conduit, correctly sized, to fit some power or control cables. The conduit is sized properly for field bends and straight runs however if the electrician needs to use an LB fitting, the minimum bend radius of the cables is too large for a standard 3/4" LB fitting.
Electrical Contractor would be required to use a larger sized LB fitting, say 1.5" and bushing reducers to make it work.
Whose task would you say this is, the Engineers' to initially have specified large LB fittings if req'd or the electricians' to wire per NEC.
Note: Wiring and raceway were called out to be 'field to route'.
Thanks!
Thanks!
