If I wanted to check the insulation on the wiring that was just pulled to a subpanel how do i do this.  It is a single phase panel (two hots a neutal and a ground).  If I test each wire between each wire would this tell me if my insulation is good or bad.  If so how does it do it if the wires are open on one end?  Does the high voltage just look for leaks between each other.
