help w/ halo ground ring
brantmacga
Señor Member
Georgia
Former Child
bidding on a cable headend site;
rfq specifies a halo ground ring around the building; not very familiar w/ these as lightning protection has been sub'd out in the past.
the building is 11.5'x20'; are the requirements to place one ground rod @ each corner? seems like the last time we ran conduit for our lightning sub-contractor we spaced them about 25' but that building was 600k sq ft.
where do i find the requirements? customer has not been a good source for information.
also they specify "inspection ports" to verify the cadwelding; is this just a handhole over each groundrod?
thanks
thanks
PM me with your E-mail. I will send you a copy of Motorola's R-56 standards for grounding. It has good info for what you are doing.
As far as the inspection port we just use 4" PVC pipe. Put the pipe in about 6-8" lower than the top of the rod and then back fill and gravel. Then just put a cap on the pipe just above grade.
I should be charging $$$$$$ :grin::grin::grin:
I have sent it. Let me know if there is any problems
Oh my goodness Ceb!
What have you done!!!
R56! Their heads will explode!!! LOL
the info was just what i was looking for.
thanks curtis.
You be welcome. One thing to keep in mind about it. It is there standard from 05. and they use the 05 NEC code for a reference. Most of the codes have not changed but it is a good idea to verify against the 08 or 11 (if you are under it already)
