germainj
- lower florida keys
Any help with this issue will be greatly appreciated.
An RV park down here in the Keys is having corrosion issues with there pedistals. The electrical inspector is siting code 551-77(d) and saying the existing pedistals are not compliant because the terminals are below the required 24". I find it hard to believe because I spoke to a rep from Milbank and they don't make a direct burial pedistal with the lugs above 16". Also, he is requiring new conductors to be pulled to the pedistals, siting code 551-80(a), all conductors shall be continuous from equipment to equipment, not allowing for any splices below the 24" rule of 551-77(d). If 551-77(d) doesn't apply I can buy new lugs and buses for the old pedistal and I won't have to pull new wires because the connection won't have to be raised up. This would save my customer a considerable amount of money not having to potentially rebuild all of the electric for around 41 pedestals with new connections and conductors. Thanks in advance with any help.
