wiigelec
 - Red Desert
2nd I get a call saying they blew a fuse in 2 120v gas hot water heaters
3rd blew a fuse in a 120v gas dryer.
What fuses are you blowing? Fuses blow on over-current, not over-voltage...
110408-2349 EDT
Electric-Light:
Why do you make the statement --- a true RMS meter is required?
What does the word voltage mean here? It will report a voltage although different than what an RMS meter would report.If you measured the output of a dimmer with a standard DVM, it won't report the voltage as seen by the light bulb and give you a false reading
Depends on the magnitude/duration of the transient and the type of fuse...When there is a large input transient voltage there is likely a sufficient i^2*t to open the fuse.
My theory: cheap Chinese incandescent bulbs. There are no incandescent bulb mfrs left in the US and a lot of stores have resorted to alternate suppliers because of the CFL issue now. Quality has gone to hell in a hand basket. I stocked up on GE bulbs when I heard the last factory shut down a few months ago but my mother buys Chinese bulbs at the Dollar Store, they don't last a month....
1st I get a call from the developer asking why the light bulbs keep burning out.
Wait, what? A fuse on a GAS water heater? I have a gas water heater, there is no electricity going to it. Are you sure they aren't messing with you? Or was it maybe an Instant Water Heater and the 120V is for the controls? Hard to imagine that causing a fuse to blow unless there was some sort of catastrophic failure, in which case the fuse sacrificed itself in the line of duty and should be buried with honors!2nd I get a call saying they blew a fuse in 2 120v gas hot water heaters
What size fuse and was it the right size for the dryer motor? Was it a TD fuse or an non-TD? It had to be a TD fuse, the only thing the 120V is for on a dryer is the tumbler motor (and controls).3rd blew a fuse in a 120v gas dryer.
It is my understanding that moving-coil meters are inherently RMS-reading.A full-wave rectified average reading calibrated in RMS on a sine wave meter (a Fluke 27 or Simpson 260, 270) will read the same as a true RMS on a sine-wave voltage, at least within its tolerance limit.
On most non-sine wave signals the readings may be somewhat different, and others quite different.
4410 .......... 27
117.9 ...... 107.0 ....... output of dimmer full on
