erickench
- Brooklyn, NY
Hi Guys, okay I came across a very interesting multiple choice question in my passbook about grounding. Here it is:
With regard to the grounding of electrical systems, it is CORRECT to state that electrical systems
A. must always be grounded
B. must be provided with a ground detector, if ungrounded
C. must always have a separate grounding conductor
D. of less than fifty volts need not be grounded
I would have thought 'B' would be the answer because the definition of 'Grounding Conductor" in article 100 is: A conductor used to connect equipment or the grounded circuit of a wiring system to a grounding electrode or electrodes. An ungrounded system has an electrode and the definition say's nothing about connecting a grounding conductor to the service neutral. What do you guys think?
