residential pricing?
daiashi
NC
Take a look at this and see what you think.I coming up with $8468.00.
2248 sq ft home 3 stories on pillings.All electric appliances.2 kitchen circuits,dish washer,fridge,range,2 bath gfci circuits,2 bath fans,2 fan lights,(all builders models),2 20 amp heat pumps,2 10 kw airhandlers,water heater,prewire for 4 ceiling fans,3 phone outlets,6 tv outlets.200 amp service,42 space mainlug 15 feet from outdoor disconnect.I priced at 22 a outlet for s.p. switches,15 rec,and 20 amp rec,then added more for my gfci,s ,appliances and such.I can provide more if needed.Wanted to see if I am in the ball park in N.C. thanks.
You sound in the ball park. I would be a little higher by not much. You may need to bump the price up for TP recpt. I would also add in a surcharge for each AFCI breaker
Thank you for the quick reply.I priced my service at $1200.00.As for the
TR rec. I think I will throw on an extra 500 to cover any problems in
installing lighting fixtures as i am only providing the cans and trims and
any unforeseen problems that may pop up.
The cans would put my price higher. $75.00 ea for can and standard trim.
