It's not the box so much as the cover.
First of all, though, let's discuss the box. You need to use the right sort of box - and the smallest 'right' box is about the size of a 5-gallon bucket. You do NOT want to use ant manner of 'conventional' box - be it "Bell,", "FS," or whatever. Conventional boxes will not keep mud and water out, but will keep the water from draining away. Conventional boxes will quickly rust away.
The next question is: What sort of 'traffic' rating do you need? The lightest, smallest covers are of a gray fiberglass/ plastic, and will tolerate the occasional footfall. (The gray plastic also blends well with concrete walks). The next level -standard with the cement boxes- is a concrete cover. Finally, if you're worried about heavier traffic, you use the cement box with a steel cover.
What you wish to avoid are the little green boxes that are used to conceal sprinkler controls.
