ceknight
I did not want to get bogged down in the details. While I respect your right to disagree, I assure all that when I say something is 'debatable,' I'm not just imagining things. Like the EPA 'guidance' regarding lead tests- I can point to EPA links that are in conflict with each other. Ditto for the vacuum issue. Ditto my reference to 2 sq. ft.
I really don't want to beat a dead farm animal on this topic, but since you posted the above claims they really ought to be challenged lest someone else be misled. Those details you don't want to get bogged down on actually matter quite a bit.
I have made serious study of the RRP, I had to because literally all of my customers own pre-1978 houses and I like to rip holes in their plaster. I've read all the published EPA crap, most of it several times, and I haven't found inconsistencies. Most of the weaknesses in their general guidance IMO gets clarified pretty well in the rather extensive FAQ.
So....if as you say you can find conflicting EPA guidance about lead testing, HEPA vacs, and (your imaginary) 2 sf EPA rule, please do us residential folks all a favor and post it. In detail. Otherwise, well, you know.
I'll also add this, for whatever it's worth: for all the hue and cry, in the first 12 months of RRP's application I've had exactly 1 job that hit the 6sf painted surface per room rule. If you're careful and plan well, you can usually cut all the holes you need in one room without worry. If I hadn't had to remove a baseboard in one room because of a 2' clog of debris in a stud cavity, I wouldn't have hit that limit once.
