NM touching heat ducts?
Is it acceptable to have NM cables in contact with heat ducts (speaking of residential forced-air systems) as those cables pass under or over them at a right angle as they make their way across the basement ceiling? If not, how much clearance would be required or what would one put in between as insulation?
As a practice, we usually run the NM under (flexible) ductwork. Here the ambient temperature in an attic can easily exceed anything a furnace would send through the ductwork.
