Can anyone tell me what the requirements are for when a main breaker is required in a distribution panel? Is there a section in the code that covers this?
I know that if the panel is rated the same as an upstream breaker feeding the panel then no main is required. I also know that if a panel is sub fed with feed through lugs then no main is required if the sub-fed panel is the same rating as the main in the upstream panel. Is this correct?
The only case I can think of where a main is required is possibly a panel located on the secondary of a transformer in order to satisfy the requirements of the secondary protection of the transformer.
