....... 3 wire feed to subpanel with no ground. .........
Chase nipple is the ground.
URD tri-plex ran inside a structure, which also has no EGC ran with it, (might be an allowed 3-wire feed to an out building), and not installed in a raceway.
Many doubled up breaker and neutral terminals.
As far as the subpanel goes, it is tapped from the feed thru lugs, and I don't see anything else wrong with it? #6 should be fine for a feed thru tap, as long as the calculated load on the sub doesn't exceed it.
Bull dog Push-matics, I still got these in my house
Everybody knows what the outside of a panel looks like, where's the pics with the cover off and a good shot of the interior?
Wow, you do need a panel fix!
What's the leech looking thing on the lower right side of the panel? It looks like something between the wall and the not flush mounted flush cover.
