Alwayslearningelec
 - NJ
 - Estimator
To obtain a license in most states the first prereq before any testing etc. has to be working the the FIELD with tools for a certain period of time. Correct? THanks.
			I would think that would probably suffice as long as your doing electrical related work in the office, such as estimating
Are you after an Electrical Contracting license or a Master/Journeyman Electrician license? That would likely have an impact on what experience you would need to have.So if I wanted to try and get my license in 6,7 8ish years I would need field experience. Working for an electrical contractor in an office would not suffice? This is NY. Thanks
Guess I need to call NY state to confirm that.
http://www.nyc.gov/html/dob/downloads/pdf/elec_lic_checklists.pdfyou have at least 7 ? years experience immediately prior to the application date, working as a journeyman electrician on the installation, alteration, and repair of wiring and appliances for light, heat, and power in, or on, buildings.
There is no NYS statewide licensing. If you're looking at New York City licensing then you can look here. It does say:
I would want a journeyman/MAster license. Well I am really after just learning everything that is needed for the journeyman/Master license so I guess I can study over the next several years and not really worry about licensing because I won't be able to obtain it with NO field experience.
