JohnDS
- Suffolk, Long Island
- Electrician
Hey guys. I have a 240v Hot Tub to wire and the name plate says:
Max Current Draw: 48amps
I just want to double check and make sure I am sizing the wire properly.
48amp x 1.25 = 60amp
I am going to use a 60a breaker with #4 wires but I'm a little confused because after the 125% rule above, the calculation lands right on the size breaker I am using. Should I go to the next size up or should I use a 60amp breaker with #4 wire?
