Finally organizing and cleaning work van
knoppdude
Sacramento,ca
I finally threw a hissy fit, because I couldn't find parts in my van several weeks ago, and bought a pack rat drawer. I am now organizing the tools, and getting a supply of materials in the drawer. The van already looks better. Prior to this, I have focused only on industrial work, and have had the ole oil bucket upend more than once. As I can see that the industrial work will wind down, I am trying to set up the van to perform service and repair work. Outside of a wide range of boxes, fittings, conduit, cable, wire, and splicing devices, receptacles, switches, etc, does any one have advice on what they would include in the minimum breaker supply? I am only going to carry enough to hopefully complete that one urgent job, then resupply as needed. This may change, and I may find I need more or less, I just don't know. Thanks for any and all responses.
We carry mostly what we install (CH) on our trucks limited normally to 60A and below. A few of other brands but no concerted effort to stock them on the trucks. We use service bodies on 3/4 ton 4x4s, with a 2wd thrown in (because I didn't think I needed it the last purchase. Wrong). Not enough room for everything. Made worse with safety gear now taking up space that was used for truck inventory.
CB's for Service Truck
About 15 years ago I noticed that my 3 trucks had a lot of new CBs that start looking like crap after a year or two in the side boxes (we work around a lot of masonry projects--lots of fine dust). Keeping them in the cardboard boxes they come in (10 or 12 to a box) ate up a lot of space. So I hit on the idea of plastic sandwich bags. CB's are small but valuable (especially 3P bolt ons, etc) and its worth it--plus keeps dust/grit out of the CB, not just an appearance thing. Added putting our IG & HG Recepts (they used to be more expensive than they are now) in baggies, too. For our work, we keep top 4 (Sq D, GE, C-H and Siemens) in push and bolt on, 15-60A, 1P, 2P, 3P on trucks--varying quantities depending on what moves the fastest. Have almost quit putting push-ons on the trucks. Lots of CBs, but the most variable/critical item.
Thanks for the information to both of you. I think I will pick up a variety of CH breakers. As for having too many, this is why I want a variety available, without having them sit in the van for two long, as they will deteriorate. If I start doing midnight emergency calls, I would like to be ready, so it will be another learning process of what to carry, and what is not needed.
Along with small selection of full size breakers I try to keep at least one of each major brand 15 and 20A twin size breakers.
Same here. I keep my breakers and other things that need to be clean and dry in the cheap plastic containers. I also place a desiccant bag in each one because temp and humidity changes here so much. Right now I'm stocking panels meter sockets and mast material due to the recent devastation.
