lighting protection
montanaklr1
New member
My question is regarding lightning protection for an antenna system. Should the air terminal be taller than the antenna mast? Will it cause interference if it is taller than the mast?
It is likely an additional air terminal is not needed for a metal antenna mast as the mast and its support structure serves as the strike termination device. If the antenna mast is within the zone of protection of other air terminals, then no additional consideration is needed. If in doubt, the structure should be bonded to the rest of the LPS using main-sized conductors and listed fittings.
See section 4.17 of the NFPA 780...
