In the top one the meters are a little too highI'm terrible at these. The top one looks atrocious, but I've never seen a anything like the second one to know if that's the wrong way to do it.
Nicer pipe job. Bu-u-u-u-u-u-ut . . .what is wrong with this picture?
I will go with separate grounding electrodes for each service disconnecting means.
The PVC running from the panels down to the ground conceals the GEC from vandalism.
Did you notice that two services feed one j-box?
Are these services on the same building?
Yes, but that is not an NEC violation.
Yes but do they run to a common electrode or sperate electrode?
So, you can feed a common raceway from seperately metered, seperately "owned" power sources (same voltage) unmarked/unidentified? I'm having trouble wrapping my brain around that one.
Sure, why not?
Besides, in my opinion NEC wise this is one service with four service disconnects.
Here are a couple I came across the last couple of weeks.
I just don't know what to say.
Vandalism at it's best. Someone hit this main breaker pretty hard.
Are those loadcenters in the top pic nema 3R? Sure dosent look like it to me
