mkgrady
- Massachusetts
I'm looking at a job to replace numerous exterior light fixtures. It's about 200 of them. Half are hanging from a porch ceiling and half are wall mounted on a porch, All of the building finishes are wood.
In the majority of the instances the existing fixtures are not installed on an outlet box. I plan to install a box where they are missing. In many instances the existing fixtures are mounted on 3 inch pancake boxes that are surface mounted.
Some of the fixtures have a shallow canopy, and where they are mounted on a pancake box the canopy does not sit flush with wall or ceiling exposing the connections to the weather. In other cases the canopys are very deep and they seem to work but there is very little room in the canopy that is filled with the pancake box.
My first question is... does it violate the code to surface mount a pancake box? It seems to me the proper way to install a pancake box is to mount it flush with the wall or ceiling surface.
Second question. When is it acceptable to install a three inch pancake box. There doesn't seem to be enough room to contain the splices.
Third question. If a fixture has a deep canopy and it is mounted on a surface mounted pancake box, and the canopy is flush with the wall or ceiling surface, does this meet code?
My hope is that none of these surface mounted pancakes are acceptable. If that is the case, I would replace them all with a four inch pancake if there is a stud there, and if not, I would install a 3 inch round old work box.
