shockingdave
- Dayton, TN
I am not certain if this is the right forum for this, but here is my question. I have a panel box with 240v total, 120 on each side of the bus. On one side I am reading 6 amps and on the other 8 amps, my question is this: "What is the acceptable amp load on the neutral?", I have always understood it to be zero, and this panel box is showing 4 on the neutral leg. I believe I may have a grounding issue or is there an acceptable level of amps on the neutral leg, without it resulting in a grounding issue.
