0031 Mineral Processing
chris kennedy
Miami Fla.
60 yr old tool twisting electrician
I'm trying to determine if the above Building use classification would be considered a Class II location by the NEC. When I plug the title into a search engine I come up empty.
Thank you.
chris kennedy
Miami Fla.
Wouldn't that be something determined by the inspection department?
Don't know. I'm trying to find out if anything used in the use/manufacturing of concrete may produce dust that would fall under 500.5(C). This is an existing plant that had a 40 electrical system inspection by an EE. I'm bidding 99 pages of PDF's with 85 photo's. Due tomorrow.:roll::)
augie47
Tennessee
I e-mailed the inspector who worked that project and asked him to add from his experience (he is a member here)
mineral process
mineral process
The best I can remember that had several locations that the equipment had to be dust proof and a testing building that was a classified location . In Chattanooga the Inspection Department requires that the classified area are determine by and Electrical Engineer on the Plans . Maybe this will help you.
