stevebea
- Southeastern PA
To the guy's out there who are doing solar jobs I have a question. Just out of curiosity, what methods are being used to ensure, track, and monitor array performance? Thanks.
I believe that some of the newer inverters have monitoring circuitry that allows for a connection to a PC ... I'm interested in this as well.....
Depends on the gear and the budget.
For inverters that have communications capabilities, the most basic approach is to talk to the inverter and/or charge controller and see what it has to say for itself. For larger projects, external devices may be used to monitor voltages and currents and that information is gathered by more traditional SCADA equipment.
Finally, for folks with a larger budget, environmental sensing is used to determine what the expected characteristics of the system are -- as in, is the array not producing because there is a cloud above the array? Is the array not producing because it's hot and the output voltage has fallen? Is the array not producing because the grid voltage is too high?
Communications can be globbed into a few types --
1). Proprietary. Companies like Enphase have their own very closed solution.
2). Industry standard. Companies like SMA and Morningstar use Modbus (or Canbus for Xantrex / Schneider), which is a widely used protocol.
3). "Web Based". A variety of companies provide a web interface (somehow ...) to their devices and you may only be able to view the performance through their web server.
The inverters in our class can be monitored via the Internet. The instructor went online and brought up the performance charts of a PV system he installed in Indiana (I am in western Michigan). He was able to show us the difference between the output of the array both before and after installing a single axis tracking system.
Way too cool!
How much of a difference did the tracking system make?
