antenna2001
Hi,
Some time ago, I think I read that when you upgrade part of a system, you are responsible for making sure that the entire system is in working order.
Say, for example that you are called to reposition a few outlets, lights, and switches during a residential kitchen remodel. Are you responsible for checking that the branch circuit supplying the range is the correct size even though you might not have to do any work on it?
Also, if while you check the kitchen supply, you find that the bedroom circuit might be overloaded. Are you responsible for fixing that too or can you just mention it to the homeowner, finish the kitchen work, and let the homeowner make the decision of whether or not he wants you to check that?
I am getting ready to start a new business and this is one of the scenarios I want to be prepared for and I don't have an answer to. I'll appreciate your help. Thanks
I don't rememer if I saw, in the NEC, something that covers this area.
