Question - The existing facilities have whole bunch of pump/motors and MCCs as well as E-stops used for hazardous locations (Class 1, Div. 1 or 2). The idea is that to install additional E-stops closer to egress for the operation personnel to stop the pump/motors in case of emergency and leave the hazardous areas faster. So the question is "Isn't true that we can simply install additional E-stops by parallel wiring them to existing E-stops including new conduit and conductors matching the existing assuming the existing installation is correct? if yes, what parameters should we look for? For example, is distance a factor (How far from existing E-stop, we can install the new one)? Should we look for the voltage rating of auxillary contactor used in conjunction with the existing e-stops? What conductor sizes should we use, No. 16, No. 18 AWG, etc? Assuming the conduit and housing of E-stops meet the requirements of Class I, Div.1 or 2.
Thank you,
			Thank you,
