Junk on my desk
gar
Ann Arbor, Michigan
EE
110604-1627 EDT
I am currently trying to clean up my desk.
In one of the piles I found a copy of "The Road to the Transistor". I had thought I had referenced this on this forum, but a search does not find any post.
This chapter to a book is very interesting and I believe quite accurate. It can be found at http://www.jmargolin.com/history/trans.htm
In 1952 in my room at the Brooklyn YMCA I made a point contact transistor from a 1N34. It oscillated. It sits on shelf in my office and someday I may see if it still works.
What a difference in the repeatability, quality, and functionality of semiconductor products today. There was no repeatability in the fabrication of point contact transistors in 1952. Also look back at the evolution of the vacuum tube from 1883 to 1950.
Searching for information on Ford's WWI (call letters) radio station (not World War 1) I came across this http://books.google.com/books?id=_6...resnum=10&ved=0CDoQ6AEwCQ#v=onepage&q&f=false
See Chapters 8, 9, and 10. It is a very interesting discussion of early radio. Eugene Donovan and William Gassett were fathers of classmates of mine, and Charlie Thomas was head of the department I worked in for a couple semesters and a summer. Gassett left Ford to serve in the Navy, and returned to Ford after the war. Two individuals in the group had been operators of WWI and sometimes played music on an acoustic record player into the microphone of the transmitter. They did not have electrical pickups. The three antenna towers were not torn down at the beginning of the war as stated but later, maybe into the 1950s. The radio station building still exists.
110605-1249 EDT
SG-1:
On several occasions I have had the opportunity to have asked persons that were pioneers in their field about what they experienced but I did not. At the time I could have ask questions I did not realize their importance or did not think to do so. When you you have the opportunity take it.
I never realized that Charlie Thomas had directly worked with Lee De Forest in radio development. Just now reading the above mentioned reference this information came to light. Maybe if I had known this at the time I worked under him I might have asked questions about early radio. I knew several hams that had early two letter original licenses, but never talked about their very early experiences, only casual comments occurred.
Howard Aiken is another that I should have asked questions of. He was the original proponent of digital computers in the mid 1930s. Aiken's machine was electro-mechanical and called the Harvard Mark-I.
My professor in a logic course was Arthur W. Burks. He was a major contributor to the design of the first electronic (vacuum tube) digital computer. Again I missed the chance to have asked questions about his involvement in those first days.
Don Sullivan, Sully in racing circles, was the father of one of my classmates. Only about 10 years ago did I learn from his son that his father was instrumental in getting Henry Ford to put an oil pump in the first Ford mono-block V-8 engine in 1932. I would like to have heard the story first hand. Sullivan knew that an oil pump was needed. So he told the test driver to swing the car from right to left as fast as possible. Every time they burned the engine out, meaning destroyed the bearings. As a result of getting the oil pump in the engine it was possible to run these engines continuously at high speed. In fact on the dynamometer test stand on endurance testing the exhaust manifolds would continuously run cherry red. http://www.thehotrodsofdearborn.com/sully/Bohn.html
Some of the above is electrical, but the major point is that when the opportunity exists, learn as much as possible from persons that were present when early new developments occurred.
1906-1907 Audion Lee De Forest
1912 about, triode vacuum tube --- Wiki does not provide clear information here
1914 http://earlyradiohistory.us/sec011.htm
1915 in history at http://en.wikipedia.org/wiki/Vacuum_tube we get to the true vacuum tube
From here on development really started to take off. There is lots of searching and reading to do.
Hazeltine was a name in the patent list on many radios, if not all in the 1930s. So in the mid 50s at the start of a semester a new person joined the Electronic Defense Group at the University of Michigan where I worked part time. His name was Barrett Hazeltine. Because of my familiarity with the name Hazeltine I ask if he was related. It was his father that founded the Hazeltine Corporation.
