Lots of good suggestions here...you will find patience and experimentation will make it work.
Here's a link to a chart with the area stations, their virtual channel numbers, and the actual "physical" channel they are transmitting on...
http://members.shaw.ca/nwbroadcasters/digitaltv.htm
Some thoughts:
Try the simplest first...aim the antenna between the target stations and see if you can get everything.
Make sure your antenna is in good order...a decent VHF/UHF yagi mounted outdoors is still the best in my opinion (it appears the Sea/Tac market has some VHF stations.) RG/6 for the coax, as mentioned.
Having a rotor would allow you to spin around north and perhaps see what's happening with the Canucks
. It would be the best to have full control over things, especially with the terrain, but will the wife want to turn the antenna? :roll: I can't get her to watch HD cable because it involves an extra step...
Try to avoid amplifiers unless you absolutely need them...strong local signals can overload them and cause grief.
If you want to go with two combined antennas, try a simple combiner first, but you may have problems caused by signal reflections being picked up by the off-axis antenna and screwing up the main signal. If you do have trouble and only one station interests you in Tacoma, the Jointenna option is a good one to avoid the reflection problems. If you search the AVS Forums you can find crazies who have stacked together two or more antennas in different directions and combined them with multiple filters to pull in stations from Des Moines, Waterloo and Cedar Rapids, Iowa. Des Moines can be a tough market because one station still operates on channel 5 (!?), and 8, 11 and 13 are also used.
Others I know use two coax feeds and switch them at the TV...not the best if there is more than one TV to feed.
Channel Master and Winegard are both good brands.
