sparkyjpb
 - S/E Michigan
Wiring a mobile home with the pedestal 24" away form it.  Does the conduit with the feeders have to go directly underground below the disconnect then up once it's under the trailer.  Or, if supported, could I come down from the disconnect, 90 over then through the skirting and obviously up into thew panel?  Inspector says the latter can't be done anymore and must go underground then up.  Didn't see anything in the code book.
