ArchieMedes
I have a question about our diesel generator (400kW), the installation's total load normally is about 50kW and we have another load also 50kW which has a switching controller (thyristor cycle controller) which switches the 50kW load at high speed the fastest is 1 cycle for 50 Hz, on and off. We noticed that if this 50kW load is being controlled (switched on and off) by the thyristor, the generator's voltage fluctuates as well. If that load is not used and the load is only lighting or motors, , the generator's is not fluctuating.
My question are:
The generator is obviously over sized but still being affected, why?
Is there any kind of voltage stabilizer / regulator to eliminate the voltage fluctuation of the generator?
Thanks in advance
My question are:
Thanks in advance
