I guess it could but why would you?We have a 400kw electric boiler 480v, 3phase (1970's) vintage that is currently controlled with SCR's and across the line contactors. The question I have is can a purely resistive heat element be controlled from the output of a VFD?
Check with the VFD manufcturer. Thay always tell me VFDs are for motors only. Changing frequency will have no effect on the heat output. What are you trying to accomplish?
Curious. Are solid state relays capable of switching fast enough for this type of application?
I use 480V SSRs to switch 480v controls with 3-10vDC. Finding small ice cube relays with contacts rated at 480v is difficult. I believe they are zero crossing and was just curiious if I could use them to control heaters via triac outputs on a plc. Not a likely project at the moment, just thinking.
Thanks,
I for one am still curious as to why you were wanting to know.Thanks everyone for help, appreciate it
