I am having to run 1/0 oflex vfd cable to a 75hp motor 400ft away from Reliance drive. The motor has #2 wire for termination. The pot head is tight to terminate the 1/0 cable. I would like to transition to the #2 in a box 10ft away. Does anyone see a problem with using single pole power distribution blocks for each conductor and grounds and bond the shield as well?
