D-log:
My interpretation of a "D" log.
D-log:
I guess the HO thinks thats a way he can save a little green.
Ok so is that something you will consider. How will you deal with comlaints about the rough-in
I will definitly have to take that into consideration when I talk to him tomorrow. As long as we are both on the same page and its in writing I wont have a problem with it.
Why horizontal?
If you put it vertical the plate will not sit flat because of the shape of log
My experience is that about 1 in 25 actually make a profit on their first log home or in-ground pool![]()
"D" logs are veneer. So basically, you have this:
"D" logs are not veneer!!
I really appreciate all the input. I looked at the job the other day and Im working on a bid now. The logs have been drilled from the bottom up about
24" and they are all about 6' apart. I will only have about 12 receptacles in the log walls and all the switches will be on stud walls. Any ideas on types of boxes to use in the log walls or ideas on cutting out for the box? I was thinking of using a 16.5 cu in square handy box.
Good to hear back,
Personally use plastic boxes as they have more room. I use a large self feed bit to plow out the hole. 2 holes per box and chisle the rest. I use a grinder and a sander to make a flat spot for the plate. I tilt the drill and plow out the bottom of the hole at an angle to allow for the wires. Some guys have made a square cutter to finnish off the hole. Don't be afraid to back cut the hole to allow for wires as long as you have enough wood to screw the box to. If you don't like hacking the nail parts of a plastic box you can use the Arlington ONE box as it made for cut in like this.
Good luck !
Does the owner still want rough only?
Are you willing to do this?
Good to hear back,
Good luck !
