During an insepection there were 2 copper pipes, one carrying hot water and one carrying cold. However the cold water pipe is all corroded and green.
The inspector believes that this might be from the bonding (which is also copper), but he believes its from leakage current.
What are some possibilities of a pipe corroding and not the other. (i assume both of them are bonded).
Is a leakage current possible? If so what tests would be done in order to verify leakage current? can you use a clamp? or megger or???
