250.4(A)5 vers. 250.32A
At a remote building (240v, 50amps), do I need to run a grounded conductor back to the main service IF I have a grounding electrode at the remote building?
Each time I read these section (250.4A5 vers. 250.32A), I come up with a different conclusion.
George Stolz
Windsor, CO NEC: 2017
Service Manager
A grounded conductor is only required if you have line to neutral loads.
An Equipment Grounding Conductor is always required, unless coping with existing work.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
I suspect there will be lighting at the building so yes you would need a grounded conductor and an egc. In the 2005 code you could use 3 wire if it met a few conditions but 2008 NEC now requires 4 wire in that situation.
raider1
Logan, Utah
What prevents me from using 240 volt luminaires?
Chris
